Hi everybody,
İ have a t3 westfalia, we came from ıstanbul. My dynamo charger some times dosen t work. İ asked 4 services interlaken but anybody fix it. Now we are in bern. Whice service can fix it?
Best regards…
Hi everybody,
Best regards…
make me a picture of the dynamo charger. which engine do you have?
I have more than 20 dynamo charger for T3 Typ2 Waterboxer 1.9 and 2.1
İt can be regulator or wire problem i am not sure. İ need to technician or services.
Hey Erman
Go ask these guys:
https://www.gilgen-autoelektro.ch/
They are in Bern and normally they are able to fix it.
He also repairs my bus.
Regards
Detach the voltage regulator and check the length of the carbon brushes. I suppose they are too short if the dyno fails only sometimes. The visible length should be 5mm or more.
thank you very much.
